Home > Maintenance & Mods (L322) > Parking sensors AGAIN - Instructions for rear replacing |
Vogue Owner Member Since: 12 Jun 2008 Location: Braintree Posts: 234 |
Hi Guys,
29th Mar 2011 5:05pm |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 34907 |
this is from rave and it appears that the sensor goes into a holder of some kind.. ... - .- -.
29th Mar 2011 5:11pm |
It looks the sensor holders have a moulded snap clip which means it probably won't come out without getting behind it. CURRENT : FFRR 2012 4.4 TDV8
29th Mar 2011 5:17pm |
you might be lucky and be able to get your hand behind to release the clips. ... - .- -.
29th Mar 2011 5:23pm |
I've had a look and there seems to be a black plastic lower boxed trim which unless you have hands like a child instead is impossible to get into CURRENT : FFRR 2012 4.4 TDV8
29th Mar 2011 5:31pm |
just a thought, one of my sensors wasnt working and it was the wiring that was chaffed and not a faulty sensor..is it defo that your sensor is faulty..
29th Mar 2011 5:34pm |
Not sure.... The sensor (passenger side rear) is not clicking , I thought the chaffed wiring usually occurred on the drivers side? CURRENT : FFRR 2012 4.4 TDV8
29th Mar 2011 5:40pm |
mine was on the off side, but might be worth a look to see if it is the wiring.. ... - .- -.
29th Mar 2011 5:42pm |
Mind you , the will be the 4th sensor replaced in 2 years , the last 3 done under warranty CURRENT : FFRR 2012 4.4 TDV8
29th Mar 2011 5:58pm |
do you pressure wash yours much, could be water causing them to fail.. ... - .- -.
29th Mar 2011 6:04pm |
Yep many times , I suppose that could be the cause - crap quality then , they should be IP rated! CURRENT : FFRR 2012 4.4 TDV8
29th Mar 2011 6:11pm |
29th Mar 2011 6:17pm |
yes there is stu, switch on the ignition without turning the engine over , then stick the range into reverse..go round and listen to each sensor , it should make a 'clicking' noise...if a particular sensor doesn't then its the one that's faulty or the sensor wiring is .. ... - .- -.
8th May 2011 7:20pm |
stu Member Since: 04 May 2011 Location: Richmond North Yorkshire Posts: 927 |
hi, thanks for the reply.
8th May 2011 7:26pm |
