Home > Maintenance & Mods (L322) > RE-PROGRAMMING LIGHT MODULE? |
WHIZZ73 Member Since: 31 Jan 2011 Location: Hemel Hempstead Posts: 55 |
Is there anyone out there that can or knows of anyone that can re-programme the light module ecu
2nd Apr 2011 11:10am |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 34914 |
why?........
2nd Apr 2011 11:13am |
I've just converted the rear lights to 2010 but with the relay in play it puts the fog light bulb warning on the dash. This is because the fog initially acts as a side and has a permanent feed. If I can re programme the light module it would eliminate the fault and I could remove the relays? |
2nd Apr 2011 11:48am |
afaik you cant do that , you can cancel light errors that appear on the dash i believe but thats about it..
2nd Apr 2011 12:00pm |
Is the LCM in the 2007 the same "type" as the early ones? I know they just upgraded the FW in them for a while. Navcoder runs on the iBus - there were some iBus legacy systems, but as the years go on there are less and less.
2nd Apr 2011 12:17pm |
