Home > Technical (L322) > FBH and heater blower speed
kimlahti
Finland 2008 Range Rover Vogue TDV8 Alaska White
Hi,
When park heating is activated on mine MY08 tdv8. It turns on heater blower at speed of 4 right away which is way too high for my taste. Also if the park heating is on and ignition is turned on park heating is stopped and started again when engine is started. Previous MY02 L322 did not behave like this and park heating continued to run with engine until max temp was reached.
I can see there is at least two versions of climate control panel available for 2006-2009 L322 without ventilated seats. Mine is -08 with E16/V39 and from ebay can be found E16/V41 manufactured 08 for MY09 I guess. I wonder if there has been made changes related to park heating?
Can anyone with MY09 tell if it works differently or should I install webasto timer and separate the park heater system from car control? Very Happy -08 3.6 Vogue
-87 951
Post #544988 24th Feb 2020 11:12am
