Home > Maintenance & Mods (L322) > 1/0 Gauge Wire From Battery to Rear on 2011 Range Rover |
Jasdip Member Since: 12 Mar 2012 Location: Canada Posts: 25 |
Hey Guys, I have a 2011 Range Rover Supercharged and am trying to run a 1/0 gauge power wire from the battery to the rear for a sound system.
22nd Mar 2020 11:37pm |
Ansi Member Since: 07 Nov 2014 Location: Muenchwilen TG Posts: 137 |
On the driver side is room enough even for an entire cable loom. I used the driver side on my 2004 when I changed the system to an Android Head unit. It's a pain in the but it’s the only way. Going outside would require an armored cable to be safe. |
23rd Mar 2020 7:50am |
GGDR Member Since: 26 Nov 2016 Location: London Posts: 3519 |
Perhaps amp vs wiring needs a look?
23rd Mar 2020 8:33am |
Did you just upgrade your amp only and keep the original speakers? I watched one of his videos which is the Range Rover Sport L494 Amplifier Upgrade, I’m not sure if that was the one you were referring to.
23rd Mar 2020 9:49am |
Roi354 Member Since: 06 Feb 2020 Location: Essex Posts: 32 |
Not only would it be easier to wire but would also protect you better if you fitted a leisure battery in the boot with a split charger.
23rd Mar 2020 9:55am |
I was looking into fitting a second battery into the trunk. I can modify my amp rack in the spare tire wheel well to accommodate the battery and use that same power while I will be running from the main battery to power that battery instead. I even have a battery already that I could use but it doesn’t match the specs of the main battery which was recommended. I currently have a capacitor installed in the back at the amp.
23rd Mar 2020 10:03am |
I lifted that cover just a bit and was able to push the harness thru. The middle-pillar section is way more of a hassle. |
23rd Mar 2020 10:15am |
The middle pillar (B-Pillar) was going to be my next question. Did you have to remove the pillar pieces or were you able to get by just by removing the black piece at the bottom of the pillar? |
23rd Mar 2020 10:38pm |
Problem is, you can't remove the black part without partially remove the upper part.
23rd Mar 2020 10:47pm |
Mine has a factory fit 1200w system.
Yes . Cheers, Greg - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - 2011 Vogue SE 4.4 with lots of toys in Stornaway |
23rd Mar 2020 11:09pm |
I ended up getting it done. That was tough!
31st Mar 2020 8:30pm |
wayneg Member Since: 05 Jun 2013 Location: South Fremantle, Australia ( ex London ) Posts: 775 |
Am I missing something here, there is a thick cable running from the battery direct to the fuse box in the rear RHS, why not take a feed from there? I believe like me all those with a second battery make connections from here.
1st Apr 2020 7:35am |
@wayneg is that part of a DT90? I've been toying with the idea of one of those - if it is, can you share your experience with it? |
1st Apr 2020 9:23am |
Roi354, I grabbed that photo from Google images, I believe its one from the Traxide instructions, http://www.traxide.com.au/diy-dual-battery...t90-c.html
1st Apr 2020 9:48am |
