![]() | Home > Technical > need your advice with my starting issue |
| bozmandb9 Member Since: 06 Dec 2010 Location: Wallingford, Oxfordshire Posts: 846 |
I can't really tell you why, but my first thought is Crankshaft position sensor. It's just ringing a bell with me, I'm sure I had a warmstart issue cured by CPS. Also the CPS wasn't throwing up a fault code.
| stan Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 8144
like boz not sure but fuel vapour or fuel sensor spring to mind... ..............................
| dan_uk_1984 Member Since: 12 Nov 2008 Location: Bude, Cornwall Posts: 3758
What if you leave the ign on for 5 seconds before starting? This will return the fuel in the rail back to tank and replenish with cold?
| mattstevenson2005 Member Since: 01 Jan 2011 Location: Manchester, UK Posts: 297
just been looking on the internet about the camshaft position sensor but most things i have read say that there should be some error codes stored. |
Tried waiting 5-10 seconds for the fuel lines to fill didn't solve anything, I will record a video of the issue so you can see what it does.
| 47p2 Member Since: 05 Oct 2010 Location: Glasgow Posts: 3010
I would say it's a CPS fault |
heres the video of an example of the starting issue, it struggled a little in the video but it has been much worse than this in over the last few days.
| Landrover Mad Member Since: 04 Jan 2011 Location: N.Ireland Posts: 33
Another avenue I would investigate is the coolant temperature sensor, the idea of the sensor being that when the car is actually starting from cold the sensor senses this and tells the ecu to provide additional fuel (basically like the old choke system).
| pretlove Member Since: 10 Feb 2011 Location: Bas vegas Posts: 1862
i think it may be the maf sensor ...you could try cleaning the maf so that you could at least rule it out |
A faulty MAf causes rough running but doesn't cause it not to start |
| kb5 Member Since: 20 Jan 2010 Location: currently in The Sudan, dont ask Posts: 63
does any one know a way of testing the fuel pump to make sure that it is this that is causing the issue? - just looked at the price and they are VERY expensive - although i could use a modified X5 part if the worse comes to the worse.
