Home > Maintenance & Mods (L322) > DPF full 4.4 TDV8 2012 |
SFM Member Since: 19 Feb 2012 Location: dordogne Posts: 258 |
What can cause the soot level to rise so quickly?
23rd May 2020 5:33pm |
GGDR Member Since: 26 Nov 2016 Location: London Posts: 3519 |
You may have another leak. Could be any joint or union. The four hoses are typical.
23rd May 2020 6:29pm |
Dolphinboy Member Since: 08 Dec 2009 Location: Bristol Posts: 3074 |
Poss an air leak, either in a pipe or poss cracked inlet manifold. mine had a minute crack which made the DPF fill up quickly. |
23rd May 2020 6:51pm |
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4248 |
Have you had a smoke test done on it? Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
23rd May 2020 8:07pm |
Dr Rob, I would not have a clue where to get one done.
24th May 2020 12:04am |
GGDR
24th May 2020 10:21am |
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3692 |
Greg will be along with a better reply, I am sure, but until then, have you carefully wiped all around it with a white tissue ??
24th May 2020 10:36am |
Would really appreciate if any one has a schematic of this joint it does seem very loose, and yes, it has oil residue around it.
24th May 2020 10:49am |
Sorry Steve but I can’t find any detail pictures of the joint but from Greg’s experience, you can be fairly confident that you have found your problem.
24th May 2020 11:02am |
Hi Baltic
24th May 2020 11:26am |
I have just had a bit of a prod and pull on mine plus a wipe round.
24th May 2020 11:35am |
Thanks Baltic
24th May 2020 12:19pm |
Hi guys,
24th May 2020 1:46pm |
Cheers Greg
24th May 2020 2:35pm |
