Home > Maintenance & Mods (L322) > 2011 battery connections
dirtymonkey38
Does anyone have a photo of their battery connections under the bonnet?
I have a 2011 TDV8 and had the fuel filter housing replaced which has cured the water in fuel circuit issue i have been having.
Im not sure if the garage that has done the work has lost a nut off the negative terminal. Its something I've noticed today while putting the ctek charger on for a top up while the car hasnt been used for a week or so, just looks to be missing a nut off the post at the back. 2011 RR Autobiography 4.4 TDV8
Post #551431 22nd Apr 2020 9:57pm
dennij
United Kingdom 2011 Range Rover Vogue SE 4.4 V8 Buckingham Blue
I can grab a photo for you tomorrow if no one responds before then
Post #551450 23rd Apr 2020 8:48am
Bushy30
United Kingdom 2011 Range Rover Vogue SE TDV8 Galway Green
https://www.fullfatrr.com/forum/topic43662...eplacement Current: 2011 FFRR Vogue SE 4.4 TDV8
Previous: -
2004 FFRR Vogue 4.4 V8 with LPG
1997 P38 4.0 SE with LPG
1997 P38 4.6 Vogue with LPG
Post #551453 23rd Apr 2020 9:28am
kevinp
Re: 2011 battery connections
Mines the same mate. I wondered the same as you. I used it for a fly lead for my charger.
Post #551454 23rd Apr 2020 9:32am
nino_nino
take look here-
https://www.fullfatrr.com/forum/topic43662.html
and some more pic
 2012 TDV8 Black Edition
2000 Disco. TD5
1975 series III
Post #551455 23rd Apr 2020 9:51am
dirtymonkey38
So this looks normal then? No nut required?
Post #551495 23rd Apr 2020 4:37pm
kooky_guy
United Kingdom 2010 Range Rover Vogue SE TDV8 Stornoway Grey
Mine's like that. Annoying as I wanted to use it for my ctek too. I found a suitable bolt next to the battery though. 2010 4.4 TDV8 Vogue SE
Post #551497 23rd Apr 2020 4:48pm
nino_nino
to me it looks like you missing this nut
2000 Disco. TD5
1975 series III
Post #551498 23rd Apr 2020 4:48pm
dirtymonkey38
Im still no clearer haha, so doesn't need a nut on it then?
My curiosity is because I've not move the car for a couple of weeks and the battery was dead, charged it up with my ctek for a few days and also installed a ctek battery sense (bluetooth battery monitor) and it was at 100% charged. Checking daily it's running down, Monday 100% @ 12.94v, Tuesday 89% @ 12.61v, Wednesday 83% @ 12.40v. Was down to 77% today so just been out for a drive and its topped up to 80% although I will check again once the surface charge has gone. Does 0.20-0.30v per day seem about right for discharge rate or have i got a drain somewhere? Obviously never thought about it before as it usually in use daily. 2011 RR Autobiography 4.4 TDV8
Post #551515 23rd Apr 2020 8:11pm
mjdronfield
As per Nino’s post, aren’t you missing that nut then? 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #551516 23rd Apr 2020 8:35pm
dirtymonkey38
yeah looks that way, if anyone knows what size i need to replace the missing one? 2011 RR Autobiography 4.4 TDV8
Post #551518 23rd Apr 2020 9:10pm
kevinp
I had a genuine Land Rover battery put on, warranty claim, by my main dealer and I can assure you there was no nut on that thread. Try moving the wire. It will be solid. It bolts on down the back I think from memory.
Post #551520 23rd Apr 2020 9:54pm
RRYorks
United Kingdom 2010 Range Rover Vogue TDV8 Barolo Black
No nut as 'standard' I used it for the ctek, standard M6? nut
Post #551559 24th Apr 2020 11:22am
Bluegreygreen Rangie 2
Australia
No Nuts.... Razz Rolling Eyes Laughing 2010 3.6TDV8 Autobiography
Bas remap, Egr deleted (blanked & via remap) , Cold air intake, Turbo back exhaust, Provent 200 catch can, Banks idash gauge, 275/55/R20
GAP Diagnostics
Past - 02 & 03 TD6 And an 1984 Classic
Post #551562 24th Apr 2020 1:27pm
dirtymonkey38
All sorted, disconnected my dashcam (thinkware F800 Pro) after fully charging the battery again and its still 100% charged after 24hrs. Might have to look into split charge systems and fit my old varta G14 battery in the boot. 2011 RR Autobiography 4.4 TDV8
Post #551793 27th Apr 2020 10:42am
