Home > Technical (L322) > Rear diff |
essex boy Member Since: 21 Jan 2017 Location: essex Posts: 199 |
Hi all
4th May 2020 8:38pm |
Sandyt Member Since: 07 Nov 2013 Location: Wraysbury Windsor Posts: 2215 |
Yours will be electronic all s/c had electronic diff |
5th May 2020 4:51pm |
Thanks for replies chaps what spec fluid will be required |
5th May 2020 5:15pm |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 7909 |
Oil specs are in the handbook and WM downloadable from the WIKI... Pete
5th May 2020 5:38pm |
appj62 Member Since: 07 Aug 2013 Location: Cheshire Posts: 424 |
2006 MY doesn't! Previous cars: S-Max 2007-2013 (only diesel I've had, good car but expensive when diesely bits go wrong, so what's the point?) Galaxy 2001-2007 Mondeo Estate 1997-2001 Sierra Estate 1993-1997 Uno Turbo 1987 -1993 Fiesta 1984 - 1987 Fiat 127 1982 - 1984 |
8th May 2020 2:56pm |
stu1 Member Since: 06 Dec 2013 Location: UK Posts: 276 |
It's very simple to check - get the car on high suspension setting, get underneath the rear diff and get your hand around the top of the diff (obviously use an axle stand or or similar under the jacking points for safety) - it it's electronic you'll find a motor there.
8th May 2020 8:03pm |
Apologies thought it went with the engine but went with the other upgrades |
8th May 2020 9:57pm |
