Home > Technical (L322) > 2008 3.6 gearbox issue |
maric995 Member Since: 04 Apr 2019 Location: zagreb Posts: 58 |
Hi,
2nd Jul 2020 6:41am |
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4245 |
Agreed, get it serviced by someone who knows these gearboxes... Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
2nd Jul 2020 8:13am |
dinger645 Member Since: 07 Jun 2020 Location: lincolnshire Posts: 3 |
Thanks guys
3rd Jul 2020 2:06am |
Fox889 Member Since: 04 Jun 2019 Location: Bury St Edmunds. Suffolk Posts: 663 |
In your instance I would suggest a 'megaflush' where 99% of the oil is flushed out & replaced rather than a 'oil & filter' change which only gets 40%-60% of the fluid out.
3rd Jul 2020 7:58am |
Gunni Member Since: 13 Jan 2018 Location: Dorset Posts: 16 |
My experience for what its worth
3rd Jul 2020 3:46pm |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 7925 |
Nothing has the same specification of the ZF oil no matter what it says on the bottle, the oil will be to the same spec but it will not have the friction modifiers that the ZF oil has..! Pete __________________________________________________ 2014 L405 Autobiography SDV8 4.4 Loire Blue Ebony interior 2011 L322 Vogue SE 4.4 TDV8 Baltic Blue. Parchment over Navy Interior. Sold 2012 L322 Autobiography 5.0 Supercharged Ipanema Sand, Jet Interior. Sold 2002 L322 Vogue 4.4 V8 Epson Green, Ivory over Aspen Interior (Fatty Offroader) Sold -Click for Project Fatty off roader- |
4th Jul 2020 11:19am |
WB Member Since: 26 May 2016 Location: London Posts: 303 |
Have a read on the ZF website and give ZF customer support a call. The ZF process is to drain, replace the sump/filter with a new one and fill with ZF oil they do not recommend a megaflush. After all would you change engine oil and leave the dirty filter? Bear in mind the age of your filter... I know there are fans of the the megaflush on here but best to do your research. |
4th Jul 2020 5:59pm |
nick4275 Member Since: 28 Sep 2018 Location: Bewdley Posts: 51 |
Been there done that - fingers crossed for you.
6th Jul 2020 7:20pm |
Update.
22nd Jul 2020 12:04pm |
