![]() | Home > Technical (L322) > Recall |
GregP Member Since: 11 Dec 2010 Location: Exmouth Posts: 1084 ![]() ![]() ![]() |
Finally got around to visiting my local stealers today to give them my VIN and see if there were any outstanding recalls on my car. It only needs the front diff doing!! Booked it in for a few weeks time. Let's hope nout happens between now and then. FFRR TD6 HSE
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35837 ![]() ![]() |
lucky you did this greg, i'm going to have to do the same with my local dealer.. |
It may be fine now but I'd rather get it fixed than have issues at a later date. It's obviously a common problem due to it being a recall. Plus it's all FOC!!! |
Tim in Scotland Member Since: 25 Mar 2007 Location: Somewhere between here and there, if not then I'm all at sea or at home in Scotland Posts: 2181 ![]() ![]() |
And you will get 12 months warranty on the new diff as if it is being down by a franchised dealer 2018 Mini Countryman Cooper S E All4 PHEV in Melting Silver - it’s whisper quiet in EV and polluter modes |
mattstevenson2005 Member Since: 01 Jan 2011 Location: Manchester, UK Posts: 737 ![]() ![]() ![]() |
its not the diff they change, they just change the front prop shaft and put a universal joint on the end that goes into the front diff, the prop shaft end that attaches to the transfer box already has the UJ on it and at the diff end the shaft just went into the diff, thats what causes the problem, the new UJ on the diff solves the issue.
... did this and no outstanding recalls...how boring.. ![]() Y. O. L. O. . |
Never mind, worth an ask I guess. FFRR TD6 HSE
Unless your UJ has been misaligned in the first place then this recall does not need doing. Unless you're in your first 30-50,000 miles then this is NOT preventative maintenance.
