Home > Technical (L322) > Rear subframe upgrade |
GraemeS Member Since: 07 Mar 2015 Location: Wagga area Posts: 2326 |
The sub-frame itself has at least different diff mounts so can't be swapped. The knuckles, upper and lower arms have different part numbers but the earlier numbers may supersede to the latest. However if the later ones have larger bushes then the knuckle + arms might be swappable as a set if the inner bushes to the subframe are the same. |
2nd Oct 2020 9:10pm |
Minilee0 Member Since: 11 May 2018 Location: Cambridgeshire Posts: 22 |
Ok thanks for the input , what I don’t get is the Land Rover parts number for the 2004 and 2011 are the same for the sub frame, the sub frame I’ve been offered comes with everything on it including hubs discs and callipers even air bags |
3rd Oct 2020 10:43am |
Vin 2A-6A subframe KHE500050, 7A+ KHE500100 according to Microcat 2012. The diff mounts are very different.
3rd Oct 2020 11:48am |
