Home > Maintenance & Mods (L322) > Corroded brake pipes |
DMRR Member Since: 14 Apr 2010 Location: Northamptonshire Posts: 2027 |
Change your MOT station or servicing garage. This sort of thing should be picked up. It is not Land Rovers fault in all honesty. Land Rover Addict
27th Apr 2011 11:01pm |
Vogue Member Since: 31 Jan 2008 Location: on the hill Posts: 3688 |
I'll second that, brake pipes are consumables are far as I am concerned, the same as tyres and wipers etc |
28th Apr 2011 11:56am |
Johnte Member Since: 23 Aug 2010 Location: North Yorkshire Posts: 733 |
Yes they are, but I would also expect them to last more than 6 years.. |
28th Apr 2011 12:13pm |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 34913 |
depends, the range rover is capable of going off road ,in water and mud so if yours has done this then its very possible that the pipes 'could' corrode prematurely... ... - .- -. click link for , FORUM WIKI HOW TO Ǝꓕ∀ꓕOꓤ PICS workshop manual downloads are in our wiki . |
28th Apr 2011 12:15pm |
Yes point taken - We have a 6 year old Renault, the brake pipes are still like new. This is what I was comparing to, but then it has never been off-road.. |
28th Apr 2011 12:22pm |
if you have a RR that has been used to launch boats and / or on very salty roads or driven by idiots in the surf (aka Clarkson) then 6 years is good going - I have seen them last only 24 months in harsh conditions |
28th Apr 2011 12:56pm |
johnatandy Member Since: 26 Feb 2011 Location: Dudley Posts: 34 |
The pipes concerned were hidden under the plastic box where the fuel filter is located so could not be seen. As an update i have changed the both front to back pipes which are split under the ns inner wing liner. Along the whole length of the pipes were corroded and broke up in about six pieces when removed. I have replaced them with the copper type pipe so hopefully no more corrosion. Still not happy with it though to have leaked so soon with no offroading done at all. I know they do corrode but on a car thats made to be offroaded frequently, you have to admit its a bit crap. After all the "that things going and what a load of crap" i am still keeping it because i do still like it. |
29th Apr 2011 2:28pm |
