Home > Technical > wierd Fan noises and whurring noise from engine help please
44ark
2006 Range Rover Supercharged Vogue SE Auto Zermatt Silver
Guys
Couple of questions in the center console behind the climate contols there seems to be a rattley fan you can hear it all the time from the moment you unlock the car is there an ecu fan or something behind there that can be easily fixed or is it something slightly more tricky as it is very annoying.
Also a couple of time once when it was hot outside and more noticible last night when the temprature dropped there was a loud what can only be described as a whurring noise under acceleration at any speed i also noticed that the car did not get up to full operating temp and also that the engine temp actually went down after a 30 min drive with some hard acceleration.
This morning however when the car was up to temp the noise dissapeared any ideas what it may be.
On a side note i have also noticed what can only be described as loose probes hanging in the engine bay one is by the coolant bottle and the other is right down the bottom by the front bumper any ideas??
The car is a 2006 superchargered
Thanks Supercharged LPG!!
Post #62589 4th May 2011 10:54am
United Kingdom 2008 Range Rover TDV8 Vogue SE Auto Stornoway Grey
A picture of said loose probe may help diagnose that one.
Fan noise in centre console...rear climate fan? Have you got the button on your lower centre dash for rear vent control? Switch them off, maybe thats it, the rear fans are noisy as hell.
The loud whirring noise under acceleration?. Maybe that's the awesome SUPERCHARGER! THE INVENTOR OF THE TERM "FULL-FAT RANGE ROVER" :
http://www.fullfatrr.com/forum/topic666.ht...vented#end
2008MY TDV8 Vogue SE, Stornoway/Jet/Piano/ RSE+DVD
2003 Defender 90 TD5 Hard Top Ruggedised
*Gone: Range Rover Vogue TD6, JE Stage 1
*Gone: Range Rover Sport Supercharged 4.2V8
*Gone: Range Rover Vogue Classic 3.9 Auto
*Gone: Land Rover Series 3 SWB
Post #62597 4th May 2011 12:41pm
elpeede
England 2003 Range Rover Td6 Vogue Auto Zambezi Silver
Re: wierd Fan noises and whurring noise from engine help ple
44ark wrote:
Guys
There is a fan, I just tollerated mine.. its just behind the small air vent to the side of the buttons on the facia. Pop off the sides to the centre console and then you will see the screws that hold the switch pannel in place. As I say I never explored mine. I guess its a 12v fan so maybe one from a PC could be found as a cheap alterantive. Or maybe a squirt of suitable lube would shut it up. 2008 Nissan Pathfinder Mammoth Sport - "Rory", 1990 110 TD CSW - "Snowy" - 2005 Freelander TD4 S - "Freddie"
Previous Landrover products - 2003 TD6 Vogue - "Jeeves/Big Bill" (Depends on mood!) - RRC TD Vogue - "Alfie", RRC v8 Fleetline "Reggie", Disco ES V8 LPG "Oscar", 101 Ambulance prototype - "Morph", 1964 SIIa Auto Powered by Jag 4.2 Lump - "Percy".
Post #62620 4th May 2011 3:16pm
CG-SC
2006 Range Rover Supercharged Autobiography Auto Zambezi Silver
The cooling fan issue that you mentioned is exactly the problem that I am having - see here: http://www.fullfatrr.com/forum/topic6127.html
I'm not having any luck in finding the root cause of the problem.... 2006MY Supercharged LPG Autobiography - Zambezi Silver with Sand/Jet/Jet Oxford Leather.....
Post #68536 14th Jun 2011 2:42pm
evanmarcus
Hmmm thats a strange problem...I m very fond of turbochargers...
but got no experience about the SUPERCHARGER... Big Cry
Turbocharger
Post #118532 21st Apr 2012 6:52am
Reformed
England 2003 Range Rover Td6 HSE Auto Java Black
The ECU fan is inside the large black box under the bonnet on the left side.
http://m.youtube.com/watch?v=jZzvDz2cOy0
I sprayed the fan with some silicon lube spray and mine is now quiet.
Have you popped the bonnet whilst its whirring and had a listen? For ages I thought mine was somewhere inside behind the vents, but for me, it turned out to be that! Reformed
Post #118534 21st Apr 2012 7:52am
United Kingdom 2006 Range Rover Supercharged Vogue SE Auto Bonatti Grey
Dangling probe could be exterior temp sensor which should be fitted behind the grill badge...
Have you got FHB fitted? Rare on an SC but a possiblity for your noise when cold, also get your belts checked as I have heard lots get noisy in the cold when worn...
Craig Thumbs Up 06 SUPERCHARGED VSE
2012 Facelift
Overfinch Conversion
22" Overfinch Alloy's & GAP Lowering Module
Jet & Ivory Interior with RE & Hybrid TV + LR iPod Kit
BRC LPG
Post #118544 21st Apr 2012 8:59am
View user's profile Send private message View poster's gallery Send e-mail Reply with quote
