Home > Maintenance & Mods (L322) > Brembo upgrade |
JustinP Member Since: 24 Oct 2010 Location: Cambridge Posts: 889 |
I've no idea about the brake cylinder question, but I can tell you that my SC has Brembos fitted to the front and sliding calipers on the rear.
5th May 2011 3:52pm |
daveo Member Since: 21 Oct 2009 Location: london Posts: 2307 |
hi, no you dont have to change your master but you will need to change the disc's and back plates, or there was a template floating around so you could cut the ones on your car, you will all so need new sensors and flexi hoses. V8 facelift Range Rover Autobiography 22" wheels.
5th May 2011 10:35pm |
porscha Member Since: 07 May 2011 Location: United Kingdom Posts: 3 |
I intend to fit the huge 6 pot Brembos to my 2003 4.4 V8. Has anybody done this? Is the master cylinder OK with these brakes? I think they go with 380mm discs. Would love to hear from anyone who has done this.
7th May 2011 7:38pm |
the late 6 pot brembo's wont fit, the mounting points on the legs are different V8 facelift Range Rover Autobiography 22" wheels.
7th May 2011 8:47pm |
Is there such a thing as early 6 pots or will none of them fit? If not, what is the best brembo upgrade for my 4.4 V8? Thanks. |
7th May 2011 10:32pm |
the early brembo were 4 pot, there may be an after market set of 6 pot but i bet they are a fortunes. you will have to go for the 4 pot if you want easy fitting unless you want to start modding V8 facelift Range Rover Autobiography 22" wheels.
7th May 2011 11:11pm |
DDsRR Member Since: 24 Aug 2010 Location: wiltshire Posts: 8 |
After reading more on line I have decided to remain with the original set up for the time due to reading about the following:
9th May 2011 6:24pm |
I understood that the L322 had Brembos as an option from new on 4.4 V8 and even on TD6. My question is what calipers did they use front and rear? And what else was changed ie master cylinder etc?
9th May 2011 8:14pm |
if you told your insurance that it had the uprated brakes as an option from the factory i cant see them loading your premium and i think most people on here would know that the brembo's are an uprated calliper but some RR owner if asked has it got brembo's on it would think your talking about guns, my point is that mr normal would have no idea if they are standard or not...
9th May 2011 9:52pm |
