Home > Maintenance & Mods (L322) > Front brakes and clean up |
Rob2529 Member Since: 22 Nov 2010 Location: Wirral, uk Posts: 1470 |
Finished my front brake change today along with a clean up of the areas underneath. My car had quite a bit of rust on the chassis and suspension components, so a good wire brush and a coat of paint and looks a load better.
5th May 2011 6:21pm |
pretlove Member Since: 10 Feb 2011 Location: Bas vegas Posts: 1865 |
looks good "RANGEISM WILL NOT BE TOLERATED"
5th May 2011 7:06pm |
3R10 Member Since: 17 Oct 2009 Location: Paris Posts: 324 |
Looks really good! What kind of rotors are those if you don't mind asking? 2000 BMW M5, Avus Blue/LeMans Leather Interior
6th May 2011 10:09pm |
Up to now I haven't noticed an improvement but there still bedding in. Hope there will be some improvement once the rears are done and bedded in. I used a stiff wire brush and then used hammerite smooth black. Can be painted direct to rust and is ment to stop it but not 100% sure that will happen, maybe slow it a bit. The rotors are britpart. Didn't want drilled and slotted just played to prevent rust but only ones I could find were these. Wanted the anticorrosion for the rears really so had to get a matching set. |
6th May 2011 11:18pm |
