Home > Technical (L322) > 4.4 TDV8 Rear Propshaft, can it be disassembled?
Discotigger
I've got a suspected failing rear propshaft centre bearing and looking on line and in the WM the Propshaft seems to be a two-piece item. It is connected at the Universal Joint with a splined shaft and bolt. There are plenty of replacement centre bearings available, however it isn't easy to get a replacement propshaft. The Propshaft, part no. LR030049 costs well over £300, but a good quality centre bearing is less than £100.
My question is how easy is it to remove the bolt to separate the two shaft parts, does the universal joint need to be dismantled to gain access or is it reachable with spanners or other tools.
Is there anybody out there with the knowledge, or have done this centre bearing replacement themselves?
TIA, Bow down
Post #588172 20th Mar 2021 5:18pm
QuebecTango
United Kingdom 2011 Range Rover Vogue TDV8 Nara Bronze
Just replaced my rear prop for an oe GKN part. The centre bearings available do not appear to be of good quality.
Once the prop is off there is a bolt & split washer to remove then split it down, it’s not easy to get off & refit the bearing. CamTech Craig on here advised to replace complete prop which is what I have just done.
Post #588251 21st Mar 2021 1:35pm
Geoff Hurst
United Kingdom 2010 Range Rover Vogue SE 4.4 V8 Java Black
I’m currently in the same boat which still doesn’t have a paddle! All advice gained is along lines of best to replace complete than fanny around, always seems to be the default answer.
Post #615808 11th Dec 2021 10:02am
Discotigger
The 4.4 TDV8 Propshaft is a two piece assembly and can be split easily (held together with a single bolt at the centre joint) so it's easy to replace just the bearing. Just make sure you get a genuine LR bearing and not an aftermarket one, as they're not as good as the original LR parts.
Post #616532 15th Dec 2021 7:28pm
Landmark
Hi just took rear prop shaft of to replace centre bearing. No number for just bearing from landrover so ordered cheap one and will relace the bearing with good quality, well that is the plan . have removed the shaft assembly and loosened the bolt inside centre joint but several taps and the two shaft don't seem to want to part company is the a knack or is is just rusty tighty.
Post #674232 25th Sep 2023 3:16pm
Henrik07
Norway 2007 Range Rover Vogue TDV8 Santorini Black
It's most likely a standard metric bearing. Take the old bearing along to your local SKF, FAG or Timken vendor, and they can very likely sort you out with an OEM quality bearing at a fraction of what LR would charge.
Fitting a no-name eastern bearing will cause regret down the road.
Good luck
Post #674329 26th Sep 2023 5:47pm
dhallworth
More often than not it’s the rubber bushing around the bearing that fails rather then the bearing itself.
Aftermarket ones don’t seem to last 5 minutes.
General consensus seems on here seems to be to replace the entire shaft. Our local specialist won’t entertain replacing just the bearing either so for me, given that it’s not exactly a 5 minute job to remove it, I’d replace the entire shaft with a GKN one from Advanced Factors.
2007 Range Rover Supercharged in Java Black with Ivory Leather
Post #674336 26th Sep 2023 8:44pm
