![]() | Home > Technical > Rear suspension knocking |
| jonminns Member Since: 07 Mar 2011 Location: Staffordshire, UK Posts: 125
Unsure to be honest, i have this issue on the drivers front so interested as to your progress FFRR 4.4 V8 Vogue LPG MY03 Black/Sand |
| dan_uk_1984 Member Since: 12 Nov 2008 Location: Bude, Cornwall Posts: 3758
I've never had success with a "visual inspection" of bushes etc. The RR is so heavy you just cant detect play. It's best when it's up on a ramp and you can put a 3 foot bar between the joints to detect play, or better still when the wheels are hanging. Any decent garage should do this.
| mercs600 Member Since: 19 Mar 2011 Location: North Yorkshire Posts: 155
I know the front has ball joints which are prone to wear and also anti-roll bar linkages which can cause this problem ! Had the same on my Merc S class and fitted 1 x cheap linkage on one side and 1 x genuine Mercedes linkage on the other - the genuine one lasted over 6 years - the cheap one 3 months ! Don't buy cheap parts it's not worth it in the end as you do the sam job twice |
| Rob2529 Member Since: 22 Nov 2010 Location: Wirral, uk Posts: 873
I would echo what Dan said. Get a jack under the offending corner and give it a good tug in all directions. The dodgy bush should show up when their is no load on it. |
Fitted the new antiroll bar linkage and had a good tug and pry on everything whist I was there - fault/noise still there and nothing evident |
| 47p2 Member Since: 05 Oct 2010 Location: Glasgow Posts: 3014
The top and bottom bushes that attach the hub assembly to the top and bottom wishbones are prone to wearing, check them. |
Thanks - I will have a look this weekend coming - if the rain ever stops |
| stu Member Since: 04 May 2011 Location: Richmond North Yorkshire Posts: 393
rain in sunny yorkshire!!!... |
Suspect it's the shock absorber - are they easy to change ? |
Shouldn't be difficult, looks like 1 bolt top and bottom, the top will be inside the boot area. You might have to remove 3 bolts from the top mounting plate but I wouldn't think it necessary. |
