Home > Maintenance & Mods (L322) > Tow Bar? |
Martin Site Admin Member Since: 24 Mar 2007 Location: Hook Norton Posts: 1665 |
Have you got the tow bar socket (armature) fitted already? |
17th May 2011 10:08am |
Wiggins Member Since: 27 Feb 2011 Location: Glasgow, Scotland Posts: 94 |
no I don't think so, I removed my tow bar cover looked up and can only see the rear crash bar |
17th May 2011 10:11am |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 34906 |
tow bar cover?..
17th May 2011 10:37am |
as in the small plastic insert in the rear bumper that can be removed for your tow bar to go, I don't think I do have this square, don't really want the full install as I don't like the look of it, and just wanted one to remove and then fit when trailering |
17th May 2011 12:38pm |
there isnt a plastic cover on the bumper... |
17th May 2011 1:24pm |
Do you have the square recepticle the tow ball slots into? |
17th May 2011 1:34pm |
I have the Overfinch rear bumper where there's a slot for the towbar, I'm not sure about this square will look when I finish work, what if there isn't a square? a full towbar needed? |
17th May 2011 1:52pm |
this is what you should see looking underneath at the back...
17th May 2011 2:06pm |
Ahhh no I dont have this, take it I would need that first before anything? |
17th May 2011 2:24pm |
if you havnt got this 'bar' and square hole and electrics then you need a new full install... |
17th May 2011 2:27pm |
Ok thanks alot for your help folks |
17th May 2011 2:46pm |
17th May 2011 2:58pm |
stu Member Since: 04 May 2011 Location: Richmond North Yorkshire Posts: 927 |
seems as good a place to post this as anywhere!!!
17th May 2011 6:30pm |
nbunney Member Since: 10 Aug 2008 Location: Lancashire Posts: 2030 |
Wiggins, you might not be able to fit a towbar with your back bumper.
17th May 2011 11:31pm |
