Home > Maintenance & Mods (L322) > Trailer connected |
Tinman Member Since: 22 Mar 2017 Location: kent Posts: 1133 |
Hi Guys
9th Jul 2021 8:16am |
kevinp Member Since: 28 Sep 2019 Location: Telford Posts: 1118 |
I have to press the button each time I select reverse with the caravan on. Annoying!!! |
9th Jul 2021 8:25am |
Furnitureman Member Since: 26 Jan 2021 Location: Leicestershire Posts: 332 |
not sure if the 2012 is different but I told my car via the iid tool that I had 13 pin electrics and it works perfect?
9th Jul 2021 8:39am |
rvbush Member Since: 08 Jan 2016 Location: Leamington Spa Posts: 520 |
My car has been told it's got a towbar, Indy did it when fitting, but the sensors still don't turn off. Drives:
9th Jul 2021 8:41am |
According to Pat from Gap, it cannot be done?
9th Jul 2021 8:46am |
Pat is a top bloke and he knows more about the iid than any of us but I’m talking from my experience and it’s on the menus to select either 7 or 13 pin which I selected the latter and my reversing sensors switch off when the trailer is connected I’m sure many others will come and say the same 2012 Range Rover Westminster 4.4 TDV8
9th Jul 2021 8:50am |
Would that be in the CCF folder? |
9th Jul 2021 8:52am |
I can’t remember exactly where it was but I’ll plug it in today and look for it 2012 Range Rover Westminster 4.4 TDV8
9th Jul 2021 8:58am |
Topman Thank`s |
9th Jul 2021 9:03am |
chefkenmore Member Since: 11 Jan 2015 Location: Fearnan perthshire Posts: 692 |
Should also stop the rear fogs coming on, on the car! Mine doesn’t also found that the options on the tool are limited to almost on or off! 2014 vogue se |
9th Jul 2021 9:05am |
IanV8 Member Since: 14 Jan 2010 Location: Dunfermline Posts: 502 |
My factory fitted tow bar on a2010 turned the reverse sensors off and also the car rear fog lights.
9th Jul 2021 9:07am |
That was what I remember now? no fog lights when plugged in? |
9th Jul 2021 9:08am |
Just had a quick search and Stan posted this a while back showing the menu on the iid showing what can be turned on/off I’ll still have a play and write down a quick how to later
9th Jul 2021 9:11am |
Why can’t I get that menu on mine?
9th Jul 2021 9:17am |
