Home > Maintenance & Mods (L322) > Steering coloum adjuster lubricant advice |
letsavit2 Member Since: 16 Oct 2010 Location: essex Posts: 854 |
i greased mine about 8 months ago, been fine... 2004 black Vogue TD6 |
22nd May 2011 10:15pm |
Reformed Member Since: 09 Oct 2010 Location: South Posts: 471 |
Thank you, grease it will be then! Reformed |
22nd May 2011 10:30pm |
You definitely shouldn't use WD40 as it acts as a solvent rather than a lubricant. It strips grease/oil off of things (that's why you use it to clean greasy tools) which then means things will wear much faster.
23rd May 2011 2:42pm |
