Home > Maintenance & Mods (L322) > Do I just hit it with a bigger hammer? |
supershuttle Member Since: 20 Mar 2011 Location: Lancashire Posts: 3641 |
still won't budge, I've left it soaking up some more WD 40 will try again next week. Got to go get beer for football tonight Geoff |
28th May 2011 12:46pm |
stu Member Since: 04 May 2011 Location: Richmond North Yorkshire Posts: 927 |
if it is this tight, heat may be your only option. when you do get it out i would suggest you don't leave it on again, without wanting to state the obvious. Current: TDV8 (3.6) RRS HSE
28th May 2011 2:37pm |
I don't tow stuff so will be happy to get it off and keep it off unless I have my bike rack on (home made - bolts to the plate) as the drop plate reduces the ground clearance at the back and doesn't look all that good either. thing! Geoff |
28th May 2011 5:36pm |
I spent yesterday removing the rear bumper anfd towbar and trying to remove the farmers hitch but without success. Today I took the assembly to my local garage where they placed it on a 20 tonne hydraulic press and applied heat with an oxyacetylene torch, it took almost 90 minutes of heating and pressing before the hitch eventually gave and came out of the slot. It's obviously never been off since the day it was fitted and now won't be going on unless I need to tow the trailer. |
7th Jun 2011 2:36pm |
Groan Geoff |
7th Jun 2011 2:38pm |
Looks like you might have the same problem as me |
7th Jun 2011 2:39pm |
