Home > Technical (L322) > Help! Passenger side deployable side step stuck |
cass Member Since: 12 Oct 2011 Location: northumberland Posts: 698 |
Most likely the pivots on the brackets stiff/siezed |
23rd Sep 2021 4:56pm |
G3BML Member Since: 22 Jul 2021 Location: Glasgow Posts: 98 |
Assume I’d need to remove the brackets and try freeing them off?
23rd Sep 2021 8:12pm |
Update : ordered a new left hand motor from Maltings. £330 arrives Tuesday so will update once I’ve fitted it! |
25th Sep 2021 11:01pm |
Fitted new step motor today. Old one had badly seized onto the hinge/bracket, to the point I had to apply heat and gentle persuasion with a hammer. I cleaned both brackets up before fitted new motor and noticed two hairline cracks on the pivoting part of the bracket. Thinking it would be fine, I fitted the new motor and reassembled everything back onto the car. Step now working… for two minutes then the hinge gave way. Now had at order a new front hinge from Maltings at the eye water cost of £225. Ouch guessing this car will keep me busy and my wallet empty ha
2nd Oct 2021 4:18pm |
Got the new bracket delivered and fitted today. Took 30 mins seeing as I have had it off just last week haha. Finally have a working deployable step.
6th Oct 2021 5:44pm |
dhallworth Member Since: 10 Oct 2011 Location: Glasgow Posts: 2990 |
It’s more then likely scrap unless you can find someone to weld it for you.
6th Oct 2021 8:39pm |
Thanks for the heads up David, will give them a shout in the future. Only had the car two days when the step failed. Fingers cross nothing else unexpected pops up and I can actually get round to sorting the other things that need doing.
6th Oct 2021 10:58pm |
muddycharles Member Since: 05 May 2011 Location: Miami, FL Posts: 83 |
HI
8th Oct 2021 9:47pm |
Motor - LR004807
8th Oct 2021 11:00pm |
Thank you !!!!!
11th Oct 2021 4:05pm |
RRV8SC Member Since: 02 Oct 2021 Location: SW London Posts: 149 |
Crikey, that's a mess. Not the repair, the old bit.
12th Oct 2021 9:24am |
Just seen your in America, part numbers I have listed are for passenger side ( left side ) in the UK. Right hand side part numbers would be, Motor : lr004808 Front Bracket : lr004810 |
12th Oct 2021 10:14am |
Not sure, maybe a one off but going to make sure to give them a dose of ACF50 and lube the pivot points with Wurth HHS2000 every couple of months just to be sure. |
12th Oct 2021 10:20am |
