Home > Maintenance & Mods (L322) > Hose Clamps |
I have a water leak and suspected it to be the valley pan gasket. Last night i got under the car and noticed the rear coolant hoses where my LPG kit has been tied into have a lot of dried coolant round the ends and could be the possible area of the leak. The current setup use's jubilee clips. I'm not a big fan as i think they strip easy and cant hold the tension very well. Is there another way of clamping the hose's and which is the best and strongest way? |
29th Jun 2011 10:36pm |
The fureing is where the LPG is tied in using a plastic T so no alloy corrosion. Could you rate the clamps in strength from strong to weak? What are the P38 ones like? |
29th Jun 2011 11:03pm |
pretlove Member Since: 10 Feb 2011 Location: Bas vegas Posts: 1865 |
this style are good ive always used these on boost hoses for high boost turbos and what have you.....
29th Jun 2011 11:40pm |
swast4 Member Since: 07 Jan 2011 Location: Wirral Posts: 69 |
Hi Rob,
30th Jun 2011 6:17am |
Ok T-bolts it is then. Does anyone know off the top of their head which size I need for the rear coolant hose's or the hose size? |
30th Jun 2011 2:17pm |
