Home > Technical > Memory set button on seat working but not memorising
AndrewT
New Zealand 2003 Range Rover 4.4 V8 Vogue Auto Oslo Blue
A bit of a strange one this.
I tried to store a setting in the seat memory by pressing the M button and then the 1 button. However, all it did was move the seat back to the old 1 position. Whichever number button I press after M it just moves it back to that position rather than storing it.
The M button doesn't light up when pressed so I thought that maybe the connection was loose but if the seat is moving to one of the preset positions and you press M then it stops moving so the switch must be connected.
I can't get the plastic side trim off the seat to have a proper look behind. I've undone the screw at the back and levered off all the tabs along the bottom but it seems to be attached somewhere at the top front and I can't find that either.
Any ideas?
Post #69075 17th Jun 2011 9:08pm
ric355
2003 Range Rover 4.4 V8 Vogue Auto Buckingham Blue
I just tried it with mine and ignition has to be on. I have nothing technical to suggest on this one, but it doesn't say anything about ignition in the manual.
Post #69078 17th Jun 2011 9:16pm
United Kingdom 2004 Range Rover 4.4 V8 Vogue Auto Oslo Blue
Andrew
You have to possition the seat where you want it, press M (should light up), memory number, then M again to finish the saving process. I think you need the ignition on as well.
Post #69080 17th Jun 2011 9:21pm
AndrewT
Tits!
Just tried it with the ignition on and all is good.
I did check the manual (honest!) and it said that the ignition only needs to be on if the door is shut.
Thanks for the help.
Post #69083 17th Jun 2011 9:29pm
ric355
AndrewT wrote:
Tits!
We're glad we could help Wink
Post #69085 17th Jun 2011 9:30pm
AndrewT
Laughing That came out a bit wrong. It was aimed at me / the manual. Very Happy
Post #69087 17th Jun 2011 9:36pm
