Home > Maintenance & Mods (L322) > Gearbox and transfer case oil |
Get some *cheap* oil of the correct spec. and keep flushing with that after driving a few km's - in UK I can get 20l of Smith and Allan ATF for ZF 'boxes for £99. Don't worry too much about the fill level being absolutely correct, just use it to get the wrong oil flushed out, then once happy, fill with the correct ZF oil, preferably with a filter change as well. Personally, whilst I was in there, I'd drop the mechatronic and change the interfaces ('rubbers') as well. |
4th Sep 2022 8:00pm |
garyRR Member Since: 13 Mar 2021 Location: Hampshire Posts: 1366 |
As Phoenix says, just cycle the gearbox for 1,000km or so with some cheaper oil of the correct specification and then drain and change the filter, replacing with the genuine ZF fluid.
4th Sep 2022 9:15pm |
GustavW Member Since: 26 May 2021 Location: Kalmar Posts: 42 |
Im on it. All good ideas.
6th Sep 2022 12:05pm |
Will change filter etc after the last flush and proper ZF fill. Fuji White 2011, 4.4 TDV8 Vogue SE |
6th Sep 2022 12:06pm |
Happydaze Member Since: 30 Aug 2021 Location: Wirral Posts: 47 |
There's a great tech article on here somewhere of a home done flush with no special tools beyond a largeish plastic tray. Invoves running the engine with the trans pan removed and a gravity fed source of new fluid. Got a bit messy when I did it but its a one time deal and gets the bulk of the fluid out. Look in the wiki.
7th Sep 2022 10:25pm |
johnboyairey Member Since: 11 Jan 2013 Location: surrey Posts: 2027 |
im in UK, I bought 8 litres of ZF lifeguard 8 and a sump/filter, for about £150, delivered from Holland. via Ebay. you can only put about 3 litres in from a drain. (tdv8 4.4 2012) |
7th Sep 2022 11:29pm |
Ok, that would be great. I cant seem to find this in the wiki - only for tdv6 and other gearboxes not the ZF8p70 one. If you know where to find it that would be really great.
8th Sep 2022 9:35am |
Apologies. I was referring to the 3.6 and now realise that you have the 4.4. Having said that, I can't find the procedure I followed successfully almost exactly a year ago, in the wiki now. Very strange.
8th Sep 2022 10:48am |
GustavW I have private messaged you the genuine ZF service procedure for the 8HP70 gearbox.
8th Sep 2022 12:14pm |
No worries!
8th Sep 2022 1:26pm |
The mechatronic seal is correct.
8th Sep 2022 2:24pm |
If the wrong oil is in now, I'd say 1000km is too much, personally I'd just do enough to warm up the transmission to running temperature and then drop the contents. You could have the whole job done in a day.
8th Sep 2022 3:20pm |
I meant if wishing to 'flush' it, put in a cheaper Lifeguard 8 for 1000km and then change the filter and ATF for genuine Lifeguard 8. 2015 Range Rover Autobiography 4.4 SDV8 |
8th Sep 2022 3:30pm |
So heres an update:
8th Sep 2022 8:14pm |
