Home > Technical (L322) > Strange EAS Fault |
garyRR Member Since: 13 Mar 2021 Location: Hampshire Posts: 1343 |
Have you tried the lock-to-lock steering trick? 2015 Range Rover Autobiography 4.4 SDV8 |
9th Sep 2022 8:21pm |
crowebeard Member Since: 19 Dec 2016 Location: Devon Posts: 93 |
Yes, after I reconnected the battery I did the normal lock-to-lock calibration and IID tool and error code cancelling. I also tried removing and replacing the negative lead to see if that would 'reset' the system but no joy.
9th Sep 2022 8:27pm |
Can you drive it above 12mph? the logic should force a levelling as it will force the front end to go to standard height, if that works, then increase to 31mph which should bring the back down to standard. I take it the EAS height LED's by the switch are operative and not flashing? |
9th Sep 2022 9:14pm |
Googs Member Since: 19 May 2022 Location: Tassie Posts: 158 |
I had some problems with the EAS fault and found it to be some sticky O-rings in the main valve block...changed these out and working perfectly.
9th Sep 2022 9:45pm |
GraemeS Member Since: 07 Mar 2015 Location: Wagga area Posts: 2309 |
The brass exhaust silencer nozzle at the compressor could be blocked. Temporarily remove the silencer to see if the system behaves. |
10th Sep 2022 1:17am |
Thanks all for your thoughts. Current situation:
10th Sep 2022 1:03pm |
If you crack off the inlet to the front block and there's a constant hiss of air (not just the line emptying), then it's the front block that needs attention. It may be easier to test with a soapy water spray.
10th Sep 2022 3:01pm |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 7908 |
I had something similar with my old 2002 off roader after drowning it in a Welsh river, I used the IID to " deflate all" a few times then re fill and do it again, maybe that was stuck valves, the water in the system didn't help...!!
10th Sep 2022 4:44pm |
Thanks for your help Pete/Pheonix
14th Sep 2022 5:58pm |
Glad you're getting to the bottom of it - before you go buying bits, are you sure the link rod is attached and articulating properly? you've probably already checked but it's a question worth asking.
14th Sep 2022 6:42pm |
David
14th Sep 2022 9:21pm |
knares Member Since: 22 Jun 2017 Location: Perth WA Posts: 701 |
i just this minute ordered two hight sensors, now i wish i had read this before i ordered them.
10th Nov 2023 10:56am |
how did you go, still got problems with mine, sounds the same as yours RR 2005 4.4 petrol
11th Dec 2023 2:45pm |
