Home > In Car Electronics (L322) > Stereo issues |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 34930 |
try the connections and if that doesn't work, it could be the amp that's knackered... |
23rd Jun 2011 10:18am |
trick202 Member Since: 23 Jun 2011 Location: Halifax Posts: 7 |
The the DSP is the amp as I presumed?
23rd Jun 2011 10:27am |
yes and yes..
23rd Jun 2011 10:40am |
Wow, many thanks for the effort - much appreciated!
23rd Jun 2011 10:45am |
the x5 should be the same providing you both have similar screens.. |
23rd Jun 2011 10:48am |
Just had a quick peep at lunchtime.
23rd Jun 2011 12:32pm |
water damage is a common problem..loads on here re that.. |
23rd Jun 2011 12:34pm |
RRUK Site Supporter Member Since: 08 Jun 2007 Location: UK Posts: 6350 |
I was just reading the first post and was thinking "I wonder if the Amp has suffered the common water ingress problem?"
23rd Jun 2011 1:19pm |
re the solution...i believe there is a plastic cover/shroud that prevents water going onto the electrics but it doesn't solve the water ingress..
23rd Jun 2011 1:33pm |
I'm just hoping that a good clean out of the plugs will solve the problem, and that the amp isn't . |
23rd Jun 2011 1:48pm |
Found this on RR.net
23rd Jun 2011 3:07pm |
Nothing on ebay but a repair service for three hundred-and-odd quid.
23rd Jun 2011 3:14pm |
daveo Member Since: 21 Oct 2009 Location: london Posts: 2307 |
fit a water jacket to the stereo, around 7 pounds from land rover and it will protect all your electrics in that rear cubby hole. a lot of RR leak there and its the nav unit that gets most of it but depends on the leak, check where your spare wheel is at the bottom,if its swimming with water then you will have condensation prob as well V8 facelift Range Rover Autobiography 22" wheels.
23rd Jun 2011 7:11pm |
Dolphinboy Member Since: 08 Dec 2009 Location: Bristol Posts: 3062 |
I have a spare, working DSP as shown in the Diag. You can have it for cost (around 80 quid if i remember.) The only trouble is I am overseas at the moment and won't be back to blighty until mid July. Can you wait that long? If not, I can get a colleague to sort it for me. |
23rd Jun 2011 10:32pm |
