Home > Maintenance & Mods (L322) > Battery drain issues with 2011 TDv8 4.4 vogue SE. |
pcourtney Member Since: 14 Jan 2020 Location: Stansted Posts: 649 |
ah that makes sense, so the "Smart System" you refer to is nothing more than what was standard spec on MY10 onwards L322 vehicles, basically the in dash informing you that the battery is low so I'm gonna shut down, all standard fare and no dealer intervention or any ECU firmware upgrades required when simply replacing a stock Lead Acid with an AGM - all of this I assume came about when JLR informed Main dealers it was the best thing to do at the time and the easiest option to get customers off their back during their 3 year warranty
11th Oct 2022 12:35pm |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7636 |
The Smart System is the smart charging system, introduced with the 4.4 TDV8 at the 2011 model year. The press pack had an embargo on it till 17th June 2010. Thought it was in the Wiki…. Not sure….
11th Oct 2022 4:34pm |
Ah, here we go….
11th Oct 2022 4:38pm |
upagreen1 Member Since: 21 Feb 2021 Location: Yorkshire Posts: 9 |
I have 2011 tdv8. it came with a Yuasa YBX5019 100ah 900a battery and I'm always getting the "low battery please start engine" warning. It doesn't seem to be an issue though, it always starts first time. |
11th Oct 2022 5:44pm |
There was an issue with that message coming up too early, Land Rover changed it with a software update I understand.
11th Oct 2022 6:12pm |
