Home > Maintenance & Mods (L322) > how to use clay bar? |
darrenmax Member Since: 20 Apr 2010 Location: antwerp Posts: 420 |
2002 td6 vogue, 06 supercharged facelift
26th Jun 2011 1:43pm |
Rob2529 Member Since: 22 Nov 2010 Location: Wirral, uk Posts: 1470 |
Shouldn't scratch if you keep kneading the clay to get a fresh peice. Some say you should use a clay lub. But you can just use water with a bit of car shampoo. The clay will remove all dirt stuck to the paint along with all wax and polish on the car. |
26th Jun 2011 2:12pm |
allycraven Member Since: 28 Mar 2011 Location: North Craigo, Angus Posts: 440 |
Megs quick detailer is a good lube - definitely speeds up the process! |
26th Jun 2011 3:28pm |
