Home > Wheels & Tyres > Your preferred tyre pressure? |
JayGee Member Since: 27 Jul 2021 Location: London Posts: 2751 |
Stock for me. Tried +10% and it just made the ride harsher. 2012 TDV8 Vogue (L322) |
17th Nov 2022 11:59pm |
Vogue Member Since: 31 Jan 2008 Location: on the hill Posts: 3696 |
Always run at the light load pressure - very very rarely 5 on board with all the luggage. I learned this with a RRC back in the 80’s running at 28 all round made a massive difference to comfort 2021 L405 Vogue SE 4.4 V8 DIESEL ~ #17 |
18th Nov 2022 10:42pm |
KitTheRam Member Since: 29 Mar 2022 Location: Essex/Herts Border (originally from Derby) Posts: 308 |
Thanks. I am going to try the stock setup for a while and see how I go. The lightest on the sticker is 33f, 36r.
18th Nov 2022 11:54pm |
I wouldn’t go under stock pressure as you will compromise handling and wear. 2012 TDV8 Vogue (L322) |
19th Nov 2022 10:08am |
appj62 Member Since: 07 Aug 2013 Location: Cheshire Posts: 424 |
Usually 34 all round. No appreciable wear and handling OK. Running on Nexen Rodians for last 9 years. Previous cars:
19th Nov 2022 12:32pm |
johnboyairey Member Since: 11 Jan 2013 Location: surrey Posts: 2026 |
I have taller walled tyres on my 20's (l322) would I keep the standard pressures, or go higher, or lower? for road cruising... (275 50 20) |
19th Nov 2022 1:53pm |
Try standard and adjust based on feel - harsh ride and sharp, light steering and it’s too high. Wallowing ride and vague heavier steering and it’s too soft. I’ve got 255/55 20 and run 33/36. Higher pressure at the rear recommended for stability and bias to under rather than oversteer. 2012 TDV8 Vogue (L322) |
19th Nov 2022 2:44pm |
Thanks.
20th Nov 2022 3:43am |
Bill Member Since: 18 Nov 2017 Location: Essex / Normandy Posts: 1174 |
There is a difference between cold standing and using, what surprised me is all four tyres will change pressure at different rates
20th Nov 2022 11:04am |
Deleted Filters are in fact so good that in certain circumstances, when the ambient air is already polluted, a diesel car will tend to extract more particles from the air than it emits. Emissions Analytics worked with........etc etc
20th Nov 2022 11:05am |
All tyre pressures on cars are set and measured cold. Likley also why the fronts on the L322 are lower pressure is that in use ) (higher load) they will inflate higher than the rears. 2012 TDV8 Vogue (L322) |
20th Nov 2022 11:14am |
I only check tyre pressures when the cars been sitting for a while and at night when the temp is more even around each wheel. Now I have ordered a more accurate gauge I will test all the tyres after a long run to see how much inflation that has occurred, I would guess 2/3psi after a motorway run? More likely on the front than the back as mentioned above. 2009 pre-facelift 3.6 TDV8. |
20th Nov 2022 1:38pm |
Hot tyre pressures checking would be useful when combined with an infra red thermometer to get the pressure vs temp and identify any issues like a binding calliper or wheel alignment errors causing scrubbing. 2012 TDV8 Vogue (L322) |
20th Nov 2022 2:10pm |
