Home > In Car Electronics (L405) > L405 Passenger Seat Randomly Moving |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 7911 |
You will need a better diagnostic tool than the basic OBD tool to read faults other than emissions...
12th Dec 2022 6:34pm |
Lyonhead Member Since: 05 Aug 2017 Location: Cardiff Posts: 349 |
Just another thing it could be,
12th Dec 2022 7:26pm |
samb096 Member Since: 11 Dec 2022 Location: Scarborough Posts: 11 |
I haven’t tried unlocking the car with the spare key that’s an idea! I’ll try that once I’m home. I’m considering disconnecting the switch pack on the left hand side of the seat for now to stop it moving, I thought this might eliminate the controls on the seat from the equation, my thinking being if it still does it with the control buttons disconnected then it’s not the seat controls however I’m not sure if its likely to put a faulty light on the dash. As I say I’m new to the Range Rover world so it’s all a learning curve! |
12th Dec 2022 8:58pm |
CS Member Since: 14 Apr 2015 Location: Edinburgh Posts: 1341 |
Looking at the 'faults list' for my L405 (a bit sad, I know) I found that my car had also experienced the random front passenger seat away as well as (separately) the random lowering of the passenger headrest. It was found to be a software fault and cured by correcting the software. Only Range Rovers since 1988 |
13th Dec 2022 2:54pm |
CS, this sounds similar to my fault. Out of interest what are you using to look at the fault log?
13th Dec 2022 3:38pm |
Sorry for the terminological confusion here, it is not a LR or similar list but my own notes of all the things that have gone wrong with my car. With my last 322 I used the back of an envelope, but found I soon needed another, so I now have a notebook (at present the total is 24 issues including corrosion items). I hope that is not too depressing news for you as a relatively new RR owner.
13th Dec 2022 8:10pm |
UPDATE- So I’ve changed the switch pack for the memory seats on the passenger side, now got all the lights working on the switch pack and as a result I’m now able to program the memory seats on the passenger side. For now I’ve programmed all 3 modes into the same position and I’ve done about 500 miles in it over the weekend and the passenger seat has stayed in the same position! Bingo! So I’m hoping this was the issue and that it’s cured it. I also changed the battery to a slightly larger unit as I was concerned about this also due to it going flat on me. However I’m fairly sure it’s the switch pack that’s cured the issue! Thanks again for all the help, I’m sure I’ll be back again with the next issue😂 |
19th Dec 2022 9:20am |
James W Member Since: 29 Nov 2009 Location: Wirral Posts: 284 |
Great fix, well done FFRR SDV8 Autobiography |
19th Dec 2022 9:52am |
Well done, glad you got it sorted. Happy Christmas all round. 19MY SVA-Dynamic Spectral Chromoflair Blue but colour not available in profile 2016 RRS SVR Estoril Blue - Gone 2010 RRS 5.0 Supercharged Navara Bronze - Gone 2008 RRS 4.2 Supercharged Black - Gone 2006 RRS 2.7 Diesel Rimini Red- Gone |
19th Dec 2022 1:07pm |
Gremlin500 Member Since: 11 Mar 2022 Location: Newcastle, UK Posts: 1222 |
@samb096:
19th Dec 2022 1:47pm |
knwatkins Member Since: 11 Sep 2020 Location: Poole, Dorset Posts: 735 |
Thanks for sharing the fix. Always useful for future Kev
19th Dec 2022 3:29pm |
