Home > Technical (L405) > SDV8 Motorway Vibrations/Unbalanced Wheel Sensation 70+ MPH |
Check brake temperature after the concern has occurred, also check dampers for leakage, you might have to take them off to do comparative tests. It's not unusual for a damper to suffer from harmonic oscillation at speed with no perceived issues on slower or rougher roads, if you have access to chassis ears, put them on the top mounts of each damper. - can you feel it through the steering or just the body? |
3rd Feb 2023 7:56pm |
ggm31v Member Since: 03 Feb 2023 Location: York Posts: 7 |
Hi,
3rd Feb 2023 8:09pm |
If they don't have 'chassis ears' or know that they are the first line of diagnosis for that sort of concern, I'd suggest somewhere else - doesn't have to be a LR 'specialist', just someone that is more interested and capable. |
3rd Feb 2023 8:42pm |
baz000000 Member Since: 01 Apr 2022 Location: Shropshire Posts: 92 |
I agree with the check you road wheel temperatures. I had a similar experience with my old L322 RR that would get the vibes above 50mph. The N/S rear road wheel was hot and the calliper seized. |
4th Feb 2023 7:38pm |
Killiestu Member Since: 23 Jan 2023 Location: Kilmarnock Posts: 21 |
Great advice, i have this exact issue on my 2013 L405. it is going in for a full fluid change shortly so i will get them to look over the brakes when its in. |
8th Feb 2023 6:25pm |
Any update on yours? @KillieStu |
21st Feb 2023 9:16am |
Hi, it looks like I have a rear damper that's knackered causing the wheel to bounce after it goes over bumps and that makes the whole car feel like there is a vibration from that corner.
21st Feb 2023 9:39am |
knwatkins Member Since: 11 Sep 2020 Location: Poole, Dorset Posts: 735 |
Do you know how they concluded this Killiestu? Kev
21st Feb 2023 7:07pm |
Yes the local RR garage took it for a drive and the mechanic took a video of the rear wheels as the drove, could see it quite clearly from about 40mph and faster |
21st Feb 2023 7:10pm |
Good info, thanks Kev
21st Feb 2023 7:16pm |
Is yours a V8? I am lead to believe the V8 has a different damper setup.......... |
21st Feb 2023 7:29pm |
No , 3.0D in mine.
21st Feb 2023 8:07pm |
I swapped all 4 wheels, and symptoms still remain.
28th Feb 2023 7:16pm |
Well a quick update from mine.
28th Feb 2023 7:24pm |
