Home > Technical (L322) > My car has a mind of its own |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7635 |
If you keep the unlock button pressed down, it will open the sunroof and open all the windows, so it could be the fob continuing to send the unlock signal when you are not holding the button.
8th Feb 2023 7:53pm |
Simran0211 Member Since: 10 Jun 2016 Location: Coventry Posts: 297 |
Yes i have tried repressing the remote when i catch it doing it, I've also changed the batteries I do have two remotes and I've also tried that method but still the same |
8th Feb 2023 7:58pm |
garyRR Member Since: 13 Mar 2021 Location: Hampshire Posts: 1352 |
Have you tried using the spare key for a while to see if it does the same? That way you can rule out if it's the car or the key causing the issue.
9th Feb 2023 1:19pm |
