Home > Technical (L322) > Is the 4.2 particularly "steamy" |
Floopy Member Since: 28 Jan 2023 Location: Chichester Posts: 73 |
I'm pretty confident the Low-Coolant is just a dodgy float in the bottle as it is sometimes fine for days and then randomly comes on for a few starts and then goes again for a while. 2006 L322 Vogue SE 4.2 |
20th Feb 2023 12:07pm |
MPx Member Since: 29 Jul 2011 Location: South Somerset Posts: 527 |
Not something I ever noticed on mine - although they do take a bit of warming up. I wouldn't expect to see any after 5 to 10 mins of running... Mike - MPx
20th Feb 2023 2:59pm |
Sandyt Member Since: 07 Nov 2013 Location: Wraysbury Windsor Posts: 2215 |
They can be if it is very cold outside also remember that the temp gauge is not an actual it sits in the middle over quite a range of temperatures to get exact you need to use a 11D tool or put in a different temp gauge . So it could be bang in the middle but just be at the bottom of the range for that position. |
20th Feb 2023 5:57pm |
oggy Member Since: 09 Sep 2020 Location: padstow cornwall Posts: 395 |
after the combustion of a gallon of petrol one pound of that is hydrogen combines with 8 lbs of oxygen to form 9 pounds of water or 1.1 gallons of water. mine does it on startup then when up to temp it is not so visible but it will always produce a lot of water more so with the new e10 fuel if you use it . new vehicle purchase
20th Feb 2023 6:17pm |
I'm using E5 fuel.
20th Feb 2023 7:56pm |
ash27 Member Since: 23 Jun 2020 Location: Hertfordshire Posts: 44 |
Mine does similar so I assume (hope!) its normal. In the cold when I am in a queue I can see it although generally on shorter trips.
21st Feb 2023 11:11am |
Good to know Ash.
21st Feb 2023 12:23pm |
tb10 Member Since: 17 Feb 2015 Location: Bromsgrove Posts: 332 |
Mine does this too |
22nd Feb 2023 9:48pm |
Bean19844 Member Since: 25 Oct 2020 Location: Essex Posts: 924 |
Mine does the same especially early hours when it's cold. Took mine for a bit of a tear up last night as was somewhat stressed so let's just say I probably got it down to 6mpg, got home 45 mins later n sat there for 5 mins. Still had a bit of condensation coming off the pipes. Nothing bad, fluids all good, high mileage at 180k so I wouldn't stress tbh but you can always do a sniff test or a compression test if it worries you |
22nd Feb 2023 11:34pm |
perhaps we should call the 4.2 supercharged engine the steamer very good for the completion steam that is new vehicle purchase
23rd Feb 2023 2:52pm |
