Home > Maintenance & Mods (L322) > Uneven Front Discs |
JDRR Member Since: 04 Apr 2023 Location: Kent / Sussex Posts: 11 |
Is there a common problem with uneven disc wear?
8th Apr 2023 2:38pm |
ttrw2 Member Since: 27 Dec 2015 Location: Oxfordshire Posts: 38 |
Sounds more likely to be the pad material and/or the pad backing plates - e.g. Mintex are notorious for being noisy, and if the back of the pads aren't greased properly, they can squeal too |
8th Apr 2023 3:03pm |
N.B -
8th Apr 2023 3:15pm |
Weegie Member Since: 09 Jun 2014 Location: East Sussex Posts: 3203 |
Warped disc? John
8th Apr 2023 4:15pm |
Weirdly, it doesn’t exhibit any other warped disc symptoms, no vibrations or wobbling under braking or high speed |
8th Apr 2023 5:11pm |
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16188 |
There will be a minimum thickness stamped into the outside lip of the disc bell... Use some callipers and measure what thickness is left would be a good starting point...
9th Apr 2023 12:43am |
Merchy Member Since: 14 Feb 2021 Location: North Wales Posts: 1142 |
As above, if it were me I would be changing the discs / pads asap, if there is a step in the disc surface, then it will be useless fitting new pads. Whilst this is being done, also check the callipers in case this has been a possible cause of any problems.
9th Apr 2023 3:25am |
Thanks all, I’ve got some Brembo discs to put on, but any pad recommendations?
9th Apr 2023 8:54am |
