Home > In Car Electronics (L322) > NavTool installed - screen is very dim |
bsolidgold Member Since: 14 Aug 2012 Location: Utah Posts: 9 |
2003 Rover - As the title states, I have successfully installed NavTool with CarPlay and it's working fantastically... When I'm in the garage with the lights off or driving at night. When I start up my truck the factory display is plenty bright but when I switch over to NavTool it's incredibly dim. I have adjusted the in-app brightness to its max and the dial by the headlight switch is set to its brightest as well. When I contact NavTool support they tell me that my screen is burnt out - but the brightness works great outside of their app. My questions are: has anyone here done the NavTool installation on their truck? If so did you have trouble with the brightness? Is the screen potentially burnt out for the mode NavTool uses but not the factory info/nav screen? Any info anyone is able to provide will be greatly appreciated. I'll trade for info on how to find/use ignition-enabled power in the back and front of your truck 😆 I'm desperate - I really want this thing to work! Thanks! |
17th Apr 2023 3:00am |
Weegie Member Since: 09 Jun 2014 Location: East Sussex Posts: 3193 |
I don’t have a truck but on my L322 with NavTool fitted my screen is normal brightness.
17th Apr 2023 8:22am |
Thanks for the reply. Your screen is different from mine as the 2005+ is touchscreen. NavTool is kind of trying to skirt the issue. That's why I'm here trying to see if it's an issue outside of their control or if their product needs work. If my screen needs reopening I'm happy to do it, but I'm not convinced. They're being less than helpful. |
17th Apr 2023 4:04pm |
I have just seen that about the screen differences. Bit basic, but perhaps worth re-checking the connections?
17th Apr 2023 4:49pm |
It works wonderfully. I recommend it - if they get the screen brightness issue sorted. And that may be a 'me' thing. It's incredibly simple to install - no work in the dash is required. It's all in the boot and automatically switches to the Android/Carplay screen when you start your car. The most challenging part was finding an ignition-controlled power source back there.
19th Apr 2023 9:40pm |
GRANGEROVER Member Since: 10 Feb 2022 Location: Bremen Posts: 24 |
Sounds good, keep us updated. Which version specifically did you buy? I only see the Carplay only version but I use an Android. |
20th Apr 2023 11:46am |
It's the same unit. The NavTool does both Carplay and Android. You select which one you have in the menu. They are not different units. John
20th Apr 2023 12:31pm |
Could you fix the problem with the screen? |
15th Jun 2023 12:30pm |
