Home > My Range Rover > Genuine Land Rover Parts |
JayGee Member Since: 27 Jul 2021 Location: London Posts: 2703 |
Yes if you use certain suppliers but you will also find that 'genuine' JLR parts are made by 3rd party manufacturers such as Brembo who also don't actually make them either and outsource them as well... 2012 TDV8 Vogue (L322) |
22nd Aug 2023 5:15pm |
TDV8_Tommy Member Since: 20 Feb 2019 Location: Pinoso, Valencia Posts: 392 |
Just go for ‘OEM’
22nd Aug 2023 7:04pm |
caymanblack Member Since: 08 Dec 2015 Location: DEVON Posts: 1057 |
I think the price for the Brembos are around £200 i believe. check they are the right ones. overfinch modified |
22nd Aug 2023 7:24pm |
'Genuine' JLR front pads are not Brembo even though the disks and calipers are. This is why they are £££££. AFAIK they are Jurid? 2012 TDV8 Vogue (L322) |
22nd Aug 2023 7:43pm |
dhallworth Member Since: 10 Oct 2011 Location: Glasgow Posts: 2984 |
Genuine LR brakes are made by Jurid.
22nd Aug 2023 9:29pm |
Proftinkerpot Member Since: 23 Dec 2022 Location: County Antrim Posts: 161 |
I got Brembo discs from Autodoc and I opted for Ferodo pads as they are supposed to be less dusty.
22nd Aug 2023 10:48pm |
Tinman Member Since: 22 Mar 2017 Location: kent Posts: 1133 |
Hi, I have been following the YouTuber who also writes on here Overlanding 4x4 L322
23rd Aug 2023 8:53am |
appj62 Member Since: 07 Aug 2013 Location: Cheshire Posts: 424 |
I changed out all my discs and pads for"Brembos", supplied by Advance Factors, several years ago. Have been all good. Previous cars:
23rd Aug 2023 9:48am |
JamboM3 Member Since: 28 Jul 2021 Location: Berkshire Posts: 157 |
That is not why they are expensive, they are expensive as they are one of the most commonly purchased parts with high margin. There is nothing special about the pads, they will however potentially be a higher quality than the off the shelf JURID IAM equivalents, probably the anti corrosion qualities and/or quality control - or not! |
24th Aug 2023 7:56am |
When I last looked Jurid pads were superior in terms of low dust. low noise and environmental aspects. I thought they were still overpriced so went with Delphi. They work well enough and the dust is mainly from the disks (i.e iron) so easy to clean off. All pads have to conform to the same friction coeficient standards so can't be more or less effective than OE so you pay the extra for the other qualities. 2012 TDV8 Vogue (L322) |
24th Aug 2023 9:12am |
Absolutely, backing plate, corrosion inhibitor coating, dust/noise down to material make up. |
24th Aug 2023 10:05am |
Nylands Member Since: 08 Sep 2019 Location: Somerset Posts: 180 |
Mine delivered yesterday from Autodoc at £90 with others advertised around £160. However you live and learn and will know better next time.
25th Aug 2023 9:06am |
Front Jurid pads for the 6pot for £90? 2012 TDV8 Vogue (L322) |
25th Aug 2023 11:00am |
No JayGee, Brembo. |
25th Aug 2023 11:37am |
