Home > Maintenance & Mods (L405) > Front lower front control arm bush L405 |
The part circled should be able to be moved by twisting, but no 'free' movement - and should bounce back if a pry bar is used to deflect it (needs wheel off the ground to check properly).
23rd Sep 2023 3:41pm |
knwatkins Member Since: 11 Sep 2020 Location: Poole, Dorset Posts: 735 |
That particular bush has quite a bit of movement and is easily flexed by hand by grabbing the arm and pushing back and forth.
23rd Sep 2023 5:28pm |
Seatown Member Since: 30 Oct 2020 Location: Mountains, seaside Posts: 83 |
Thanks for the replies chaps. On that basis I think the front arm bushes are perfectly normal then!
23rd Sep 2023 6:51pm |
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16171 |
FYI there is a revised ARB bush from JLR available... Has a return surface on the revised bush |
24th Sep 2023 1:20pm |
Thanks Craig - what do you mean by a return surface please?
25th Sep 2023 9:47am |
