Home > Off Topic - Other Cars > SDV8 'Crate' engine |
Ennoch Member Since: 26 Dec 2015 Location: Scotland Posts: 109 |
If you know what you're doing with wiring and mapping then anything's possible, although you'll probably need to use a standalone ECU like a Links or Syvecs etc. That way you can essentially map the sensors into the appropriate channels, and then custom map it. It might be possible to use the original RR ECU for some of the engine channels, but if you were then integrating an original digital (Rather than mechanical) dash cluster you may run into trouble given they'll not be speaking the same language. An engine is an engine basically, and it'll have sensors like any other engine. There's nothing special about them per se, and thus anything can be made to work given the time, budget and ability.
28th Sep 2023 9:36pm |
