Home > Technical (L322) > L322 auto lights and wipers |
tymh Member Since: 21 Apr 2014 Location: Garstang Posts: 299 |
Hello sages!
13th Oct 2023 9:16pm |
Full-fat-Lance Member Since: 06 Feb 2022 Location: Essex Posts: 113 |
I wonder if you’ve got an aftermarket windscreen and that’s throwing out the sensors 🤷🏻♂️ |
13th Oct 2023 11:13pm |
I’ve had the car a year and the wipers used to work properly. Only really noticed the lights issues over the last month.
14th Oct 2023 9:03am |
Where’s the best place to get a new sensor, and are the y difficult to fit please? Tym
14th Oct 2023 9:04am |
garyRR Member Since: 13 Mar 2021 Location: Hampshire Posts: 1367 |
Main dealer for a new sensor, its about £70. Easy to fit - clip off the mirror surround and you'll see it. Unplug the multiplug, use some tooth floss to saw the gel pad behind it to remove it. Clean up any residue with acetone or alcohol cleaner and a plastic scraper, fit the new one. 2015 Range Rover Autobiography 4.4 SDV8 |
14th Oct 2023 9:08am |
Thanks Tym
14th Oct 2023 9:09am |
JayGee Member Since: 27 Jul 2021 Location: London Posts: 2789 |
There's also a wiring issue under the drivers seat on the main loom
14th Oct 2023 9:40am |
I’ve seen that one 😉. However, I’d assumed that as his is next generation that the wiring might be different. Also, mine doesn’t consistently fail. Tym
14th Oct 2023 9:42am |
madnessgonemad Member Since: 28 Aug 2020 Location: Kent Posts: 80 |
My 2012 model had the wiring fault. It’s very easy to check the loom for damage. It could be that your wires are beginning to fail. I would have thought it would be worth checking before you buy the part.
14th Oct 2023 3:54pm |
My lights work on auto, there’s just a short delay at night. Wipers erratic Tym
14th Oct 2023 11:04pm |
