Home > Technical (L322) > Dunlop air bags - knocking |
vs322 Member Since: 08 Apr 2020 Location: Athens Posts: 531 |
Are you sure it's not the drop links? They are rather inexpensive and easy to replace. Also, I think there should be a warranty on the struts should they turn out to be the culprit. |
1st Dec 2023 5:52pm |
Merchy Member Since: 14 Feb 2021 Location: North Wales Posts: 1142 |
Same thoughts as in the above post, plus it may be that whoever fitted the new parts made a mistake when working on the car ? If both are causing the knocking sound then I rather doubt that the parts are faulty, a quick MOT style inspection whilst the car is up on a lift could reveal where the problem is. |
1st Dec 2023 6:37pm |
JayGee Member Since: 27 Jul 2021 Location: London Posts: 2759 |
You had the complete stut and not just the airbag replaced? If so shocks can knock and have had this on other cars. 2012 TDV8 Vogue (L322) |
1st Dec 2023 7:57pm |
Slow progress Member Since: 30 Jun 2020 Location: Derbyshire Posts: 443 |
Both have been changed, droplinks were the first port of call, no improvement. The knocking has only started since the struts were changed. We’ve tried it on the shaker table, and it sounds like the struts but both have been replaced in the past 12 months….however found this article and it feels the same position;
2nd Dec 2023 11:18am |
I did have a Dunlop front strut that was knocking. Replaced both with Arnott, which in turn, after 60K km seem to knock slightly when the weather is cold for the first couple kilometers of the day...Nothing as bad as the Dunlop though and definitely something I can live with. |
2nd Dec 2023 7:11pm |
That’s helpful, not sure if you can still get the Delphi ones so they’d be a good back up L322 TD6 2003
2nd Dec 2023 8:32pm |
Weejock Member Since: 31 Dec 2011 Location: UK Posts: 416 |
Delphi brake and suspension units, designs, intellectual rights and production lines were bought out by BWI in 2010. 'Delphi' suspenion units are still made but under BWI name. |
2nd Dec 2023 10:47pm |
