Home > Technical (L322) > Bi-Xenon Adaptive Headlamp Connector Pin-Out diagram? |
lschwarcz Member Since: 18 May 2019 Location: Hillsboro, OR, USA Posts: 268 |
Hi everyone,
19th Jan 2024 6:42pm |
GraemeS Member Since: 07 Mar 2015 Location: Wagga area Posts: 2326 |
This is for MY10-12 but the headlight connector is very likely to be the same as yours.
19th Jan 2024 8:43pm |
Thanks GraemeS,
19th Jan 2024 10:24pm |
The connectors should have cavity numbers, either at the front or at the back. |
20th Jan 2024 2:54am |
4RRS Member Since: 13 Apr 2022 Location: Stafford Posts: 119 |
Links below for the electrical wiring diagram for the 2009 LHD L322, 4.2 Petrol SC.
20th Jan 2024 3:44pm |
No wire lengths on those diagrams - very unusual for LR. |
20th Jan 2024 8:43pm |
As it turns out, yes, the car side of the connection does have some markings but I'm not really able to make them out. I would need to find my old macro attachment to get a good photo of them. But, as it turns out, I fixed it! This is the time for me to embarrass myself a bit. When I first started to diagnose the issue I took continuity readings with my ohm meter which all read good in the headlamp assembly. Stupidly I did not plug the unit in and take voltage readings! If I did I would have initially seen that the socket is getting 12 VDC just as it should! UGH! I sprayed some electrical contact cleaner in the socket and used a very small awl to tighten the connectors and plugged the bulb back in. Yep, that's all it needed! Thanks everyone for your help! Larry. 2009 Range Rover L322 Autobiography Bournville/Ivory Save lives, give blood. |
25th Jan 2024 7:58pm |
Good that it was a simple fix.
25th Jan 2024 8:42pm |
