Home > Maintenance & Mods (L322) > second battery |
I have a second battery in the boot area simply wired in parallel with the front battery using the existing 100A cable supplying the rear fuse board. I deliberately disconnected my front battery, left the car for a couple of days in cold weather then started it using the rear battery only simply to see if the 100A cable would be ok.
26th Jan 2024 10:54pm |
bobsin Member Since: 21 May 2015 Location: wolverhampton Posts: 50 |
I fitted a second auxilary battery, Second battery in boot supports all systems when ignition off, main starting battery for starting/running isolated when ignition off, reconnects when ignition on via a 200amp relay, original heavy duty cable direct to starter still in place, only the system connection isolated, so ZERO drain on main starting battery, both charge with split charging wiring when running, and 13.9 lovely volts. Fitted a digital voltmeter in place of analogue clock, which I've kept, as android head unit has Internet time aligned display in any case.. Second battery connected with an 80amp resettable trip in-line to protect vehicle loom...
31st Jan 2024 3:33am |
