Home > Technical > Windscreen wipers sit too high up the screen
carlos50
United Kingdom 2007 Range Rover TDV8 Vogue Auto Java Black
Hi all
My windscreen wipers sit too high on the front screen, the drivers one about 1.5" above the black surround on the glass and very visible from inside the car. I can push them down to where they should sit but after use they return to the wrong resting position.
Can they be adjusted / removed and reset?. I recall this issue on my 03 and when i took the arm off there was a hex head nut which wouldn't allow the correct amount of adjustment so is there something that can be done with the linkage perhaps?.
Thanks
Carl
Post #74712 4th Aug 2011 10:05am
England 2005 Range Rover Td6 HSE Auto Cairns Blue
take it off and replace further round on the spline...
Post #74713 4th Aug 2011 10:07am
carlos50
Thanks scarey, i thought it was a hex head type connection hence the question Embarassed
Post #74714 4th Aug 2011 10:09am
carlos50
Scarey, ive read up on this now and see where i was mistaken but i don't have a puller to be able to pull the splined bit off the stem, will i need one?.
Post #74735 4th Aug 2011 1:05pm
depends how 'stuck' the wiper is....you might be lucky and it comes straight off but i'm sure with a bit of wiggling or/and a screwdriver under it, it will come loose..
Post #74739 4th Aug 2011 1:48pm
T24RES
United Kingdom 2008 Range Rover TDV8 Vogue SE Auto Buckingham Blue
If you can borrow a puller i'd recommend using one, takes moments and saves damaging anything Thumbs Up
Post #74759 4th Aug 2011 5:18pm
carlos50
What type of puller will I need? I have no idea where I'd get one from but think it will be useful to have one incase its needed
Post #74763 4th Aug 2011 5:52pm
ian, cant seem to find your thread showing the puller etc, can you link it here please.. Thumbs Up
Post #74764 4th Aug 2011 5:52pm
T24RES
Certainly sir......http://www.fullfatrr.com/forum/post51584.html#51584
I bought mine from Halfords
Post #74773 4th Aug 2011 6:37pm
Post #74775 4th Aug 2011 6:42pm
carlos50
Thanks gents, how much are they to buy?
Post #74776 4th Aug 2011 6:44pm
T24RES
Something similar to this, most car parts shops will have something similar.http://www.ebay.co.uk/itm/SYKES-PICKAVANT-...255636347b
Post #74814 4th Aug 2011 8:05pm
cheap as chips... Thumbs Up
Post #74817 4th Aug 2011 8:11pm
carlos50
I agree, thanks again everyone
Post #74828 4th Aug 2011 8:42pm
carlos50
Ok, so I borrowed a puller in the end, got the socket etc that I needed and got ready to adjust the wiper arms and put new blades on.
I took the cap off the drivers side one and removed the nut. I noticed the spacer and washer were tight so pulled gently only to see the spacer fly off and into the bottom of the inner wheel arch so now I can't attach the arm correctly.
A trip to the dealers for me tomorrow, hope it doesn't rain
Post #74929 5th Aug 2011 4:34pm
