Home > Maintenance & Mods (L322) > Motorised "buzzing" noise within dash
aph202
United Kingdom 2012 Range Rover Autobiography 4.4 V8 Orkney Grey
Afternoon folks!
Total newb here - bought my first L322 yesterday! Wanted one forever: this is my first Range Rover or even Land Rover. So far loving the Command driving position, the wafting and the torque! I think I am a convert!! Cool
Got a funny noise coming from the dash though, I thought you folks might have an idea. When I first get going, there is a buzzing (motor-like) sound coming from behind the dash, almost behind the glove box/sat nav screen. If I switch the climate control fully off, it goes away and doesn't seem to return when I turn the climate control back on again.
I have done a bit of searching on this site and found some chat about a cabin temperature sensing fan. https://www.fullfatrr.com/forum/topic64215...ng+climate
I know absolutely nothing about this and am not entirely technical. Is this cabin temperature sensing fan a common issue and/or a likely culprit? Given it goes away when I turn off the climate, I wondered if the two are related.
Thanking you in advance,
Adrian.
Post #685630 14th Feb 2024 5:24pm
Proftinkerpot
Northern Ireland
It is the series of stepper motors that control where the air is directed to when the fans run. At least I think that's what they do. MY 2012 Westminster is in at the minute having that issue addressed - noisy fan motor and sounds behind the dashboard. Parts are not too expensive but there is a fair bit of work to strip the dash to access the parts.
I will update when I get mine back hopefully tomorrow evening. I will see if I can get pics of the removed parts so you know what you are looking for.
Post #685653 15th Feb 2024 12:17am
wayneg
Have a read, it might help.. https://www.fullfatrr.com/forum/topic50136.html 2007 TDV8 VSE
2003 TD6 gone.
2002 P38a gone
1999 P38a gone
1997 p38a gone
1993 VSE gone
1992 VSE gone
Post #685660 15th Feb 2024 6:08am
aph202
Thank you kindly! 🙏
Post #685661 15th Feb 2024 9:36am
