![]() | Home > General > Wheel buckled!! |
| Fox Member Since: 02 Apr 2010 Location: Essex Posts: 2162
Which garage did you buy it from?
| stan Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 8152
its unusual for OE wheels to buckle but they do sometimes, sounds like aftermarket jobbys, can you confirm the wheel/tyre size ..first thing to do for your own comfort would be to put the offending wheel to the back of the range cos you shouldn't feel it to much there, second would be to look for a replacement rim and maybe like richard says a set of wheels/tyres on ebay.. |
| killatomato Member Since: 15 Jul 2011 Location: Wirral Posts: 30
Hi thanks for the reply's. I got them on the car, They are 20" autobiography wheels with 275/45/20 tyres. Which I now know are the wrong size for a FF! The tyre fitter says they are OE, but I doubt it. The wheel looks fine, no scuffs or scratches but when you see it on the balancing machine you can see the wheel has been bashed a bit. My concern is, putting it on the rear will that do harm to the drivetrain? |
| nicedayforit Member Since: 11 Jun 2011 Location: Beside the sea Posts: 582
If you can see the wheel is buckeled when spinning on a balancing machine and you can feel vibration from it thro the steering wheel I would suggest replacing the wheel, even on the back you could cause premature wear of drive train components. It's not inconceivable the buckle could get progressively worse.
putting it on the rear would be a temporary solution and it wont damage the drive train in the short term...if funds are tight just get a one wheel and stick the damaged one in the spare.. |
Unfortunately my spare is a 18". So it looks like I need to find a replacement. Jag-land want £300 for I rim. Does any ony know where I can get one cheaper? |
| Tim in Scotland Member Since: 25 Mar 2007 Location: Somewhere between here and there, if not then I'm all at sea or at home in Scotland Posts: 2125
Try one of the specialist Land Rover breakers - there are some good ones out there if you google them 2012MY RREvoque Dynamic Lux Plus Auto SD4 Coupe in Fuji White with full ebony interior
They also come up on ebay from time to time...
| nbunney Member Since: 10 Aug 2008 Location: Lancashire Posts: 1473
I've got 5 x 19" wheels and tyres for sale if you are stuck and I would let you have them for not much more than a rim |
