Home > Technical (L322) > Fluid leak around the passenger front wheel (power steering) |
JMC Member Since: 01 Feb 2009 Location: Aberdeen-Angus Posts: 721 |
Check for a split in that CV joint boot. The older I get, the more I realise that people confuse wrinkles for wisdom |
3rd Mar 2024 7:52pm |
KitTheRam Member Since: 29 Mar 2022 Location: Essex/Herts Border (originally from Derby) Posts: 308 |
Thanks. Will do. Seems quite a burst of oil, some still very slightly dripping from the plastic shroud.
3rd Mar 2024 8:24pm |
It may not be the boot, but I had one split once on my old Vogue and it looked like Ron Jeremy had been spaffing black stuff in there for weeks!! The older I get, the more I realise that people confuse wrinkles for wisdom |
3rd Mar 2024 9:20pm |
Sounds about right. I’m no mechanic - is it something like transmission fluid that is leaking from the split boot (if it is that). No idea of what the CV joint entails.
3rd Mar 2024 10:34pm |
It's just grease, but friction temperature makes it like sticky WD40! The older I get, the more I realise that people confuse wrinkles for wisdom |
3rd Mar 2024 11:01pm |
Turns out it’s a power steering fluid leak.
6th Mar 2024 9:27pm |
garyRR Member Since: 13 Mar 2021 Location: Hampshire Posts: 1343 |
RAC mean beat me to it!
7th Mar 2024 4:07am |
That was going to be my next guess after the CV boot....... The older I get, the more I realise that people confuse wrinkles for wisdom |
7th Mar 2024 9:00am |
Thanks. Good advice.
7th Mar 2024 11:29pm |
What’s the best website for exploded diagrams for L322’s?
10th Mar 2024 10:01am |
Red Hot one Member Since: 09 Dec 2018 Location: Herefordshire Posts: 153 |
The workshop manual in the WIKI has a clear diagram with all the components, section 211-02, steering system. It also has all the torque values etc.
10th Mar 2024 7:02pm |
Brilliant thanks. 2009 pre-facelift 3.6 TDV8. |
10th Mar 2024 7:29pm |
dhallworth Member Since: 10 Oct 2011 Location: Glasgow Posts: 2973 |
Land Rover have their own Classic Parts website with diagrams, part numbers and prices which is fantastic.
10th Mar 2024 10:03pm |
Cool thanks. 2009 pre-facelift 3.6 TDV8. |
10th Mar 2024 10:27pm |
