Home > Technical (L322) > Query - slightly lazy cranking - any clues? |
Danb_220_2019 Member Since: 02 Jan 2023 Location: Suffolk Posts: 250 |
It may be different behaviour but before worrying about anything else, make sure the battery is good - it's not unusual for battery voltage to be fine at rest but drop drastically under cranking when the battery is in less than perfect condition without any other symptoms. 2012 (L322) 4.4TDV8 Vogue SE, RSE, Fuji White over Arabica.
20th Mar 2024 2:07pm |
D3Jon Member Since: 15 Aug 2020 Location: Lincolnshire Posts: 368 |
Sounds most likely to be a battery issue, or wiring related such as a loose battery terminal, dirty battery terminals or a bad earth lead to the engine block.
20th Mar 2024 3:29pm |
Weegie Member Since: 09 Jun 2014 Location: East Sussex Posts: 3194 |
I had something slightly similar. My indie replaced a badly corroded earth and that made quite a difference but, as has been said, it could be a number of issues starting with battery and progressing to alternator. John
20th Mar 2024 5:59pm |
