Home > Maintenance & Mods (L322) > Brake Pad Warning |
It will reset when you replace the cable & sensor |
7th Aug 2011 6:53pm |
pretlove Member Since: 10 Feb 2011 Location: Bas vegas Posts: 1865 |
i had to turn mine off using diagnostic tool "RANGEISM WILL NOT BE TOLERATED"
7th Aug 2011 7:04pm |
It takes a couple of ignition cyles, and I always found I had to leave the ign on for about 15 seconds for it to register, but the sensor goes open circuit to give you the warning. When you put a new sensor on and it goes closed circuit the message will go away. There is no pad wear sensor replacement option in T4 etc... What diagnostics tool did you use to clear it? |
7th Aug 2011 7:32pm |
just a standerd obdII with scan software ...but you may have been right about the ignition cycle as i turned it off as soon as i noticed that it hadnt gone out so didnt give it much of a chance to go out by itself...........a little off topic , ive got an airbag light that needs to be reset any ideas on software i can use to do that or is it gonna be rac, faultmate "RANGEISM WILL NOT BE TOLERATED"
7th Aug 2011 7:34pm |
RAC'll do it... |
7th Aug 2011 7:36pm |
am i right in saying you cant just use there software with your own obdII / usb plug "RANGEISM WILL NOT BE TOLERATED"
7th Aug 2011 7:37pm |
Correct... |
7th Aug 2011 7:39pm |
