Home > Technical (L322) > ABS and SAS Communication |
Iwheels Member Since: 26 Feb 2024 Location: Alberta Posts: 14 |
Checked continuity of the lime green wire was pretty weak so I opened the connection. This is what I found. Guess I gotta pull the pins and clean it better
3rd Apr 2024 12:15am |
Dolphinboy Member Since: 08 Dec 2009 Location: Bristol Posts: 3065 |
this is exactly what the Stealer/main dealer failed to check and wanted to charge me £1000 for a new ABS sensor on my 4.4 Petrol!! A quick rub down with a toothbrush and a bit of contact spray and it was all fixed forever! |
3rd Apr 2024 2:05pm |
Used some electrical cleaner and there were about eight of the pins that were badly corroded so I spliced them with butt connectors, but this might not be good enough?
4th Apr 2024 12:22am |
